Salta al contenuto principale
Garmin Nuvi 2455LMT Speaker Replacement
Cosa ti serve
  1. Garmin Nuvi 2455LMT Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver. Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Speaker Replacement: passo 2, immagine 1 di 2 Garmin Nuvi 2455LMT Speaker Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
  3. Garmin Nuvi 2455LMT Speaker Replacement: passo 3, immagine 1 di 3 Garmin Nuvi 2455LMT Speaker Replacement: passo 3, immagine 2 di 3 Garmin Nuvi 2455LMT Speaker Replacement: passo 3, immagine 3 di 3
    • Open the device carefully being weary of the orange band that is going from the screen to the mother board.
  4. Garmin Nuvi 2455LMT Speaker Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 2455LMT Speaker Replacement: passo 4, immagine 2 di 2
    • Using the plastic prying tool, carefully pry the speaker from the plastic backing.
    • Remove the speaker from the motherboard by gently pulling on the wire.
Conclusione
USF Tampa, Team 2-3, Blackwell Fall 2016 Membro di USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 223
