Salta al contenuto principale
Garmin Nuvi 2455LMT Back Panel Assembly Replacement
Cosa ti serve
  1. Garmin Nuvi 2455LMT Back Panel Assembly Replacement, Back Panel Assembly: passo 1, immagine 1 di 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 2, immagine 1 di 2 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 3, immagine 1 di 3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 3, immagine 2 di 3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: passo 3, immagine 3 di 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-3, Blackwell Fall 2016 Membro di USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 956
