Salta al contenuto principale
Garmin Nuvi 200w Screen Replacement
Cosa ti serve
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: passo 1, immagine 1 di 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: passo 1, immagine 2 di 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: passo 1, immagine 3 di 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: passo 2, immagine 1 di 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: passo 3, immagine 1 di 3 Garmin Nuvi 200w Screen Replacement: passo 3, immagine 2 di 3 Garmin Nuvi 200w Screen Replacement: passo 3, immagine 3 di 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 200w Screen Replacement: passo 4, immagine 2 di 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: passo 5, immagine 1 di 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: passo 5, immagine 2 di 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: passo 5, immagine 3 di 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: passo 6, immagine 1 di 3 Garmin Nuvi 200w Screen Replacement, Screen: passo 6, immagine 2 di 3 Garmin Nuvi 200w Screen Replacement, Screen: passo 6, immagine 3 di 3
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 346
