Salta al contenuto principale
Garmin Nuvi 200W Rear Cover Replacement
Cosa ti serve
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: passo 1, immagine 1 di 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: passo 1, immagine 2 di 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: passo 1, immagine 3 di 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: passo 2, immagine 1 di 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: passo 3, immagine 1 di 3 Garmin Nuvi 200W  Rear Cover Replacement: passo 3, immagine 2 di 3 Garmin Nuvi 200W  Rear Cover Replacement: passo 3, immagine 3 di 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 200W  Rear Cover Replacement: passo 4, immagine 2 di 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 248
