Salta al contenuto principale
Garmin Nuvi 200 Speaker Replacement
Cosa ti serve
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: passo 1, immagine 1 di 2 Garmin Nuvi 200 Speaker Replacement, Rear Casing: passo 1, immagine 2 di 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 200 Speaker Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    there is no use showing how to replace a speaker in nuvi if we cant find any
    seems like a god dam mistery
    Jean Michel Tche - Replica
  5. Garmin Nuvi 200 Speaker Replacement: passo 5, immagine 1 di 1
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: passo 6, immagine 1 di 3 Garmin Nuvi 200 Speaker Replacement: passo 6, immagine 2 di 3 Garmin Nuvi 200 Speaker Replacement: passo 6, immagine 3 di 3
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
Conclusione
Altre 3 persone hanno completato questa guida.
Anjelica
Membro da: 04/11/10
564 Reputazione
3 Guide realizzate
Cal Poly, Team 25-90, Amido Spring 2010 Membro di Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Membri
9 Guide realizzate
2 Commenti
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Replica
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 7,061
