Salta al contenuto principale
Garmin Nuvi 200 Battery Replacement
Cosa ti serve
  1. Garmin Nuvi 200 Battery Replacement, Rear Casing: passo 1, immagine 1 di 2 Garmin Nuvi 200 Battery Replacement, Rear Casing: passo 1, immagine 2 di 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Battery Replacement: passo 2, immagine 1 di 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Battery Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 200 Battery Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Battery Replacement, Logic Board: passo 4, immagine 1 di 1
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 200 Battery Replacement: passo 5, immagine 1 di 1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 200 Battery Replacement: passo 6, immagine 1 di 2 Garmin Nuvi 200 Battery Replacement: passo 6, immagine 2 di 2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 200 Battery Replacement: passo 7, immagine 1 di 2 Garmin Nuvi 200 Battery Replacement: passo 7, immagine 2 di 2
    • Detach the logic board form the battery by pulling out the cable.
  8. Garmin Nuvi 200 Battery Replacement, Battery: passo 8, immagine 1 di 2 Garmin Nuvi 200 Battery Replacement, Battery: passo 8, immagine 2 di 2
    • Do not use any sharp objects around the battery, as these may puncture the battery.
    • Remove the battery by pulling it away from the casing.
    • The battery is glued to the casing.
Conclusione
Altre 18 persone hanno completato questa guida.
Anjelica
Membro da: 04/11/10
564 Reputazione
3 Guide realizzate
Cal Poly, Team 25-90, Amido Spring 2010 Membro di Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Membri
9 Guide realizzate
13 Commenti
This document could be improved by including information about where to acquire a replacement battery, and any modifications that might be required to a generic battery.
Jonathan Moore - Replica
Seems like there are some on Amazon and Ebay. Not sure how to verify getting the right one. Not that expensive, so maybe worth the risk.
Jim Carnicom - Replica
It was a huge mistake to peel away the ribbon cable. It needs matched up precisely and exactly in the same alignment as it was before during reassembly, an apparently impossible task once it's been detached. I'd advise opening the halves in book form, leaving the ribbon cable as a hinge. Have about given up trying to position it.
Nice tutorial, except for the booby trap.
gepetto4 - Replica
Yep, fell into this trap, too. The Nuvi powers up but no video. Can't place the ribbon cabe just exactly so. Ugh.
webo666.666 -
Cannot stress enough that the step 5 calling for the removal of the tape holding the ribbon cable be removed from this guide! My Nuvi will not work anymore because I can't get that ribbon cable aligned. I wish I had read all the comments as the above poster warned of this very problem. Please update the guide and remove step 5!
Jarrod - Replica
A question from Rich: After many years of use , the connector on the back for the charging cord seems loose . This results in power loss when the cord move or giggles as you go down the road. Is the connector directly in the battery ? Can I replace the connector only? Is it part of the battery and must the battery be replaced ? Thanks
rich brooks - Replica
did you ever find out if the power connector is attached to battery I have a problem where the garmin powers off on every bump jack wiggles ? do you know if it can be fixed
Donald Krams -
As others have mentioned, step 5 is not needed to change the battery and you will practically brick the nuvi because its impossible to perfectly align the cables. I wish I had seen more videos and instructions and read the comments. As it stands this are not good instructions for changing the battery.
Douglas Novo - Replica
I can't agree with the others - I disconnected the cables in step 5 and had no problems reconnecting them when putting it all back together. Battery changed and everything is running smoothly. You just need a calm and steady hand.
eismann - Replica
After 5 or 6 tries to realign this cable I have pretty much given up. Like mentioned before DON"T REMOVE THE TAPE OR THE CABLE!
minivangranma - Replica
Agree with eismann, with calm and steady hand, it’s not that difficult to push the screen connector to the mainboard, then clap the plastic plate back to hold it. And you can do it with nuvi 200 powered on, once the screen is connected, screen will turn white, then you can restart it.
Ziling Zhang - Replica
Can anyone helped me to put back the switch on/off after I change the battery the switch it is not back proper since can not back to work when I want to start on . Please helped me how I can fix it?
highflyer - Replica
I followed the directions exactly and now have a fully functional GPS! Thank you!
Chris Petry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 55
Tutti i Tempi: 48,030
