Salta al contenuto principale
Garmin Nuvi 1490T Speaker Replacement
Cosa ti serve
  1. Garmin Nuvi 1490T Speaker Replacement, Front Frame Panel: passo 1, immagine 1 di 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Speaker Replacement: passo 2, immagine 1 di 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Speaker Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 1490T Speaker Replacement: passo 3, immagine 2 di 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: passo 4, immagine 1 di 3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: passo 4, immagine 2 di 3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: passo 4, immagine 3 di 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Speaker Replacement: passo 5, immagine 1 di 3 Garmin Nuvi 1490T Speaker Replacement: passo 5, immagine 2 di 3 Garmin Nuvi 1490T Speaker Replacement: passo 5, immagine 3 di 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Garmin Nuvi 1490T Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
  7. Garmin Nuvi 1490T Speaker Replacement: passo 7, immagine 1 di 2 Garmin Nuvi 1490T Speaker Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, gently clamp onto the white plastic end of the speaker connector.
    • Remove it by pulling slightly towards the speaker.
  8. Garmin Nuvi 1490T Speaker Replacement: passo 8, immagine 1 di 3 Garmin Nuvi 1490T Speaker Replacement: passo 8, immagine 2 di 3 Garmin Nuvi 1490T Speaker Replacement: passo 8, immagine 3 di 3
    • Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Slide the tool around the perimeter to fully dislodge the speaker.
Conclusione
Ricardo Solis
Membro da: 01/20/16
1.037 Reputazione
6 Guide realizzate
USF Tampa, Team 15-2, Remmell Spring 2016 Membro di USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 252
