Introduzione
Use this guide to replace your Garmin Nuvi 1490T display screen.
Cosa ti serve
Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
Gently disconnect the display by pulling upward. Set display aside.
Altre 5 persone hanno completato questa guida.
Un commento
Awesome!! Thank you for putting this out there. Helped me save buying a new gps when the screen on my got damaged.
