Salta al contenuto principale
Garmin Nuvi 1490T Battery Replacement
Cosa ti serve
  1. Garmin Nuvi 1490T Battery Replacement, Front Frame Panel: passo 1, immagine 1 di 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Battery Replacement: passo 2, immagine 1 di 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Battery Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 1490T Battery Replacement: passo 3, immagine 2 di 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Battery Replacement, Second Frame Panel: passo 4, immagine 1 di 3 Garmin Nuvi 1490T Battery Replacement, Second Frame Panel: passo 4, immagine 2 di 3 Garmin Nuvi 1490T Battery Replacement, Second Frame Panel: passo 4, immagine 3 di 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Battery Replacement: passo 5, immagine 1 di 3 Garmin Nuvi 1490T Battery Replacement: passo 5, immagine 2 di 3 Garmin Nuvi 1490T Battery Replacement: passo 5, immagine 3 di 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Battery Replacement, Display Screen: passo 6, immagine 1 di 3 Garmin Nuvi 1490T Battery Replacement, Display Screen: passo 6, immagine 2 di 3 Garmin Nuvi 1490T Battery Replacement, Display Screen: passo 6, immagine 3 di 3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
  7. Garmin Nuvi 1490T Battery Replacement: passo 7, immagine 1 di 2 Garmin Nuvi 1490T Battery Replacement: passo 7, immagine 2 di 2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
  8. Garmin Nuvi 1490T Battery Replacement: passo 8, immagine 1 di 3 Garmin Nuvi 1490T Battery Replacement: passo 8, immagine 2 di 3 Garmin Nuvi 1490T Battery Replacement: passo 8, immagine 3 di 3
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
  9. Garmin Nuvi 1490T Battery Replacement, Battery: passo 9, immagine 1 di 3 Garmin Nuvi 1490T Battery Replacement, Battery: passo 9, immagine 2 di 3 Garmin Nuvi 1490T Battery Replacement, Battery: passo 9, immagine 3 di 3
    • Using the T5 Torx screw driver, remove the two 5.0 mm screws.
    • Using your hands, lift up the motherboard and fold it over.
  10. Garmin Nuvi 1490T Battery Replacement: passo 10, immagine 1 di 3 Garmin Nuvi 1490T Battery Replacement: passo 10, immagine 2 di 3 Garmin Nuvi 1490T Battery Replacement: passo 10, immagine 3 di 3
    • Fold motherboard out of the way to reveal the white plastic end of the battery plug.
    • Using the tweezers, pull the white plastic connector to disconnect the battery from the motherboard.
    • Let the cord hang unattached.
  11. Garmin Nuvi 1490T Battery Replacement: passo 11, immagine 1 di 2 Garmin Nuvi 1490T Battery Replacement: passo 11, immagine 2 di 2
    • Return motherboard back to original position by flipping it back over.
    • Using the nylon spudger, dislodge the battery out of its socket.
    • Use a tool that is ESD-safe such as a nylon spudger or a plastic prying tool. Never use a metal spudger to take out the battery.
Conclusione
Altre 7 persone hanno completato questa guida.
Ricardo Solis
Membro da: 01/20/16
1.037 Reputazione
6 Guide realizzate
USF Tampa, Team 15-2, Remmell Spring 2016 Membro di USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Membri
6 Guide realizzate
2 Commenti
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1490T Battery 361-00019-16
Mike - Replica
Thanks for the great instructions! Had I not given up on Garmin's video instruction I'm sure I would have destroyed my GPS. You saved the day for me. Again, THANKS!
Mike Billmaier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 47
Tutti i Tempi: 5,782
