Salta al contenuto principale
Garmin Nuvi 1390LMT Battery Replacement
Cosa ti serve
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: passo 2, immagine 1 di 2 Garmin Nuvi 1390LMT Battery Replacement: passo 2, immagine 2 di 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: passo 3, immagine 1 di 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 1390LMT Battery Replacement: passo 4, immagine 2 di 2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: passo 5, immagine 1 di 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: passo 6, immagine 1 di 2 Garmin Nuvi 1390LMT Battery Replacement: passo 6, immagine 2 di 2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: passo 7, immagine 1 di 1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: passo 8, immagine 1 di 2 Garmin Nuvi 1390LMT Battery Replacement: passo 8, immagine 2 di 2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Trey Ulsh
Membro da: 10/22/15
537 Reputazione
3 Guide realizzate
Montana Tech, Team 10-4, Shirk Fall 2015 Membro di Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 Membri
3 Guide realizzate
Un commento
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,784
