Introduzione
This Garmin had a cracked front glass/digitizer. Due to cost effectiveness I replaced the complete front panel. Replacement cost $20.
Cosa ti serve
The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
Remove the holder as well as the power cord from the back of the GPS unit.
The Nüvi uses two screws that are hidden underneath the label on the bottom.
Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
The ribbon cable and connector are covered with a strip of Kapton tape
Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
Altre 3 persone hanno completato questa guida.
2 Commenti
Thank you! Saved me a new GPS!
