Salta al contenuto principale
Garmin Nüvi 205W LCD Display Replacement
Cosa ti serve
  1. Garmin Nüvi 205W LCD Display Replacement, LCD Display: passo 1, immagine 1 di 3 Garmin Nüvi 205W LCD Display Replacement, LCD Display: passo 1, immagine 2 di 3 Garmin Nüvi 205W LCD Display Replacement, LCD Display: passo 1, immagine 3 di 3
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
  2. Garmin Nüvi 205W LCD Display Replacement: passo 2, immagine 1 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 2, immagine 2 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 2, immagine 3 di 3
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
  3. Garmin Nüvi 205W LCD Display Replacement: passo 3, immagine 1 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 3, immagine 2 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 3, immagine 3 di 3
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
  4. Garmin Nüvi 205W LCD Display Replacement: passo 4, immagine 1 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 4, immagine 2 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 4, immagine 3 di 3
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
  5. Garmin Nüvi 205W LCD Display Replacement: passo 5, immagine 1 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 5, immagine 2 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 5, immagine 3 di 3
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
  6. Garmin Nüvi 205W LCD Display Replacement: passo 6, immagine 1 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 6, immagine 2 di 3 Garmin Nüvi 205W LCD Display Replacement: passo 6, immagine 3 di 3
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
Conclusione
Altre 3 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
785.103 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
574 Guide realizzate
2 Commenti
After reinstalling LCD screen how do I reconnect the ribbon cable? Any tips would be GREATLY appreciated :) Thank You
John - Replica
Thank you! Saved me a new GPS!
worthless0000 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,356
