Salta al contenuto principale
Garmin GPSmap 60CSx Keypad Buttons Replacement
Cosa ti serve
  1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: passo 1, immagine 1 di 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 2, immagine 1 di 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 3, immagine 1 di 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 3, immagine 2 di 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: passo 4, immagine 1 di 2 Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: passo 4, immagine 2 di 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 5, immagine 1 di 1
    • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • The previous step will need to be done to the other three corners.
    • It is best to do the two bottom corners first.
    • Pull the black PCB board out of the GPSMap 60 CSx.
  6. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 6, immagine 1 di 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 6, immagine 2 di 2
    • Carefully use a spudger to lift the PCB a few centimeters.
    • Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • This will pull out all the main components including the antenna and the screen.
  7. Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 7, immagine 1 di 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: passo 7, immagine 2 di 2
    • Take the front panel and apply light force to the buttons.
    • The buttons are part of one unit and should all pop out at once.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 3,046
