Salta al contenuto principale
Garmin Forerunner 25 Motherboard Replacement
Cosa ti serve
  1. Garmin Forerunner 25 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Motherboard Replacement: passo 2, immagine 1 di 1
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Motherboard Replacement: passo 5, immagine 1 di 1
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
Conclusione
IUPUI, Team S5-G3, Baechle Spring 2018 Membro di IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 821
