Salta al contenuto principale
Garmin Forerunner 25 Battery Replacement
Cosa ti serve
  1. Garmin Forerunner 25 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: passo 2, immagine 1 di 1
    • Pry the old battery out using a plastic spudger.
Conclusione
IUPUI, Team S5-G3, Baechle Spring 2018 Membro di IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Membri
5 Guide realizzate
11 Commenti
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - Replica
I need to know as well. What kind of battery is it? PD…????
girlie_360 - Replica
Just look at the last picture. PD2430C1
Leandro Lind - Replica
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - Replica
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 81
Tutti i Tempi: 6,303
