Salta al contenuto principale
Garmin Fenix 3 HR Motherboard Replacement
Cosa ti serve
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: passo 2, immagine 1 di 2 Garmin Fenix 3 HR Motherboard Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: passo 4, immagine 1 di 2 Garmin Fenix 3 HR Motherboard Replacement: passo 4, immagine 2 di 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: passo 5, immagine 1 di 1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: passo 6, immagine 1 di 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: passo 7, immagine 1 di 1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: passo 8, immagine 1 di 1
    • Now attach battery to new motherboard and reassemble.
Conclusione
Altre 5 persone hanno completato questa guida.
Jacob Smiley
Membro da: 03/26/18
277 Reputazione
1 Guida realizzata
IUPUI, Team S1-G6, Harley Spring 2018 Membro di IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Membri
5 Guide realizzate
2 Commenti
And where would one source replacement motherboard?
jonathan.hatchuel - Replica
donde puedo encontras placa.madre reeemplazo????
luis zavala - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,004
