Salta al contenuto principale
Garmin Fenix 3 GPS Antenna Replacement
Cosa ti serve
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: passo 1, immagine 1 di 2 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: passo 1, immagine 2 di 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: passo 2, immagine 1 di 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: passo 3, immagine 1 di 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: passo 4, immagine 1 di 1
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: passo 5, immagine 1 di 1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: passo 6, immagine 1 di 1
    • Carefully remove the antenna, and set it aside.
Conclusione
8 Commenti
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - Replica
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - Replica
Hi did you find gps antenna
Abdessamad Faroque - Replica
Could you please add a link where to buy the antenna?
marco475 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 44
Tutti i Tempi: 5,255
