Introduzione
If your watch face is damaged, cracked, or chipped, you can learn how to replace it using this guide. This guide involves simply unscrewing screws from the watch face and carefully disconnecting the screen’s ribbon cable from the motherboard. You will need a T6 Torx screwdriver and a spudger.
Cosa ti serve
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Altre 4 persone hanno completato questa guida.
3 Commenti
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
I have the same question.
