Salta al contenuto principale
Garmin Fenix 2 Housing Replacement
Cosa ti serve
  1. Garmin Fenix 2 Housing Replacement, Watch Straps: passo 1, immagine 1 di 1
    • Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
  2. Garmin Fenix 2 Housing Replacement: passo 2, immagine 1 di 1
    • Use a Torx T9 screwdriver to remove the four .8mm screws. Once the screws are removed the watch straps should fall out of the housing.
  3. Garmin Fenix 2 Housing Replacement, Battery: passo 3, immagine 1 di 3 Garmin Fenix 2 Housing Replacement, Battery: passo 3, immagine 2 di 3 Garmin Fenix 2 Housing Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  4. Garmin Fenix 2 Housing Replacement: passo 4, immagine 1 di 2 Garmin Fenix 2 Housing Replacement: passo 4, immagine 2 di 2
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  5. Garmin Fenix 2 Housing Replacement: passo 5, immagine 1 di 2 Garmin Fenix 2 Housing Replacement: passo 5, immagine 2 di 2
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
  6. Garmin Fenix 2 Housing Replacement, Motherboard: passo 6, immagine 1 di 1
    • Use a spudger to pry open the power ribbon from the main board.
  7. Garmin Fenix 2 Housing Replacement: passo 7, immagine 1 di 1
    • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
  8. Garmin Fenix 2 Housing Replacement: passo 8, immagine 1 di 1
    • Use the spudger to pry the motherboard out of the housing.
  9. Garmin Fenix 2 Housing Replacement: passo 9, immagine 1 di 1
    • Once removed simply separate the digitizer from the main board.
  10. Garmin Fenix 2 Housing Replacement: passo 10, immagine 1 di 2 Garmin Fenix 2 Housing Replacement: passo 10, immagine 2 di 2
    • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
  11. Garmin Fenix 2 Housing Replacement, Display: passo 11, immagine 1 di 1
    • The display is also ready to be replaced.
  12. Garmin Fenix 2 Housing Replacement, Housing: passo 12, immagine 1 di 2 Garmin Fenix 2 Housing Replacement, Housing: passo 12, immagine 2 di 2
    • Use a spudger tool to pry the soundboard out of its housing.
  13. Garmin Fenix 2 Housing Replacement: passo 13, immagine 1 di 1
    • Remove the gasket seal from the housing.
  14. Garmin Fenix 2 Housing Replacement: passo 14, immagine 1 di 1
    • Once all your components are removed the housing with buttons is ready to be repaired/ replaced.
Conclusione
Altre 5 persone hanno completato questa guida.
Brandon Barger
Membro da: 02/13/16
1.219 Reputazione
5 Guide realizzate
IUPUI, Team 54-4, Wilson Spring 2016 Membro di IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Membri
7 Guide realizzate
2 Commenti
Hi there!
Thanks for the tutorial!
When i reassemble the watch, do i have to put some glue to seal the tiny holes out of the soundboard, or those rubber rings does the job?
I’m just afraid of screwing the waterproof feature of the watch…
Thanks!!
Antenor Heleodoro dos Santos - Replica
do you know where i can find atmospheric pressure and temperature sensors?
marco turati - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,372
