Salta al contenuto principale
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
Cosa ti serve
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: passo 1, immagine 1 di 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: passo 1, immagine 2 di 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: passo 2, immagine 1 di 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: passo 2, immagine 2 di 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: passo 3, immagine 1 di 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: passo 3, immagine 2 di 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: passo 3, immagine 3 di 3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,567
