Salta al contenuto principale
Garmin Edge 1000 Back Cover Replacement
Cosa ti serve
  1. Garmin Edge 1000 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Garmin Edge 1000 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Back Cover Replacement: passo 2, immagine 1 di 2 Garmin Edge 1000 Back Cover Replacement: passo 2, immagine 2 di 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 56
Tutti i Tempi: 5,855
