Salta al contenuto principale
Garmin Drive 60LM Motherboard Replacement
Cosa ti serve
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Garmin Drive 60LM Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Motherboard Replacement: passo 2, immagine 1 di 3 Garmin Drive 60LM Motherboard Replacement: passo 2, immagine 2 di 3 Garmin Drive 60LM Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Motherboard Replacement: passo 3, immagine 1 di 3 Garmin Drive 60LM Motherboard Replacement: passo 3, immagine 2 di 3 Garmin Drive 60LM Motherboard Replacement: passo 3, immagine 3 di 3
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Motherboard Replacement: passo 4, immagine 1 di 2 Garmin Drive 60LM Motherboard Replacement: passo 4, immagine 2 di 2
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
  5. Garmin Drive 60LM Motherboard Replacement: passo 5, immagine 1 di 2 Garmin Drive 60LM Motherboard Replacement: passo 5, immagine 2 di 2
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
Conclusione
Andy Flores
Membro da: 01/30/17
238 Reputazione
2 Guide realizzate
Baylor, Team 3-3, Whitney Spring 2017 Membro di Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Membri
3 Guide realizzate
2 Commenti
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - Replica
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,395
