Salta al contenuto principale
Garmin Dezl 770LMT Screen Replacement
Cosa ti serve
  1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: passo 1, immagine 1 di 2 Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: passo 1, immagine 2 di 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Screen Replacement: passo 2, immagine 1 di 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Screen Replacement: passo 3, immagine 1 di 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Screen Replacement, Screen: passo 4, immagine 1 di 2 Garmin Dezl 770LMT Screen Replacement, Screen: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
  5. Garmin Dezl 770LMT Screen Replacement: passo 5, immagine 1 di 3 Garmin Dezl 770LMT Screen Replacement: passo 5, immagine 2 di 3 Garmin Dezl 770LMT Screen Replacement: passo 5, immagine 3 di 3
    • Now you have the screen, which is enclosed by another cover. Remove the eight screws that hold it in place.
  6. Garmin Dezl 770LMT Screen Replacement: passo 6, immagine 1 di 1
    • Once the screws have been taken out, use a spudger to carefully remove the cover. With this cover removed, the screen is now completely exposed.
Conclusione
Altre 3 persone hanno completato questa guida.
Aleem Waris
Membro da: 10/10/16
146 Reputazione
1 Guida realizzata
USF Tampa, Team 1-3, Lacy Fall 2016 Membro di USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,905
