Salta al contenuto principale
Garmin Dezl 770LMT Battery Replacement
Cosa ti serve
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: passo 1, immagine 1 di 2 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: passo 1, immagine 2 di 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: passo 2, immagine 1 di 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: passo 3, immagine 1 di 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: passo 4, immagine 1 di 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: passo 4, immagine 2 di 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: passo 4, immagine 3 di 3
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: passo 5, immagine 1 di 2 Garmin Dezl 770LMT Battery Replacement: passo 5, immagine 2 di 2
    • Grasp the wire near the mother board and gently lift to detach the battery.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 1-3, Lacy Fall 2016 Membro di USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 25
Tutti i Tempi: 6,068
