Salta al contenuto principale
Garmin Dezl 760LMT Speaker Replacement
Cosa ti serve
  1. Garmin Dezl 760LMT Speaker Replacement, Back Panel: passo 1, immagine 1 di 2 Garmin Dezl 760LMT Speaker Replacement, Back Panel: passo 1, immagine 2 di 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Speaker Replacement: passo 2, immagine 1 di 3 Garmin Dezl 760LMT Speaker Replacement: passo 2, immagine 2 di 3 Garmin Dezl 760LMT Speaker Replacement: passo 2, immagine 3 di 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Speaker Replacement: passo 3, immagine 1 di 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Speaker Replacement, Speaker: passo 4, immagine 1 di 2 Garmin Dezl 760LMT Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
    • Slide the metal probe underneath the speaker and pry upwards.
    • During reassembly, use electrical tape to hold the speaker into place.
  5. Garmin Dezl 760LMT Speaker Replacement: passo 5, immagine 1 di 2 Garmin Dezl 760LMT Speaker Replacement: passo 5, immagine 2 di 2
    • Grasp the speaker wire near the motherboard and lift upward to detach the connector.
Conclusione
USF Tampa, Team 4-2, Passmore Fall 2016 Membro di USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 531
