Salta al contenuto principale
Gamestop G3 Gamecube Left and Right Trigger Replacement
Cosa ti serve
  1. Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: passo 1, immagine 1 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: passo 1, immagine 2 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: passo 1, immagine 3 di 3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 2, immagine 1 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 2, immagine 2 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 2, immagine 3 di 3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 3, immagine 1 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 3, immagine 2 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 3, immagine 3 di 3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
  4. Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: passo 4, immagine 1 di 2 Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: passo 4, immagine 2 di 2
    • Remove the screws holding the plastic bumper cover in place and remove it.
  5. Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 5, immagine 1 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 5, immagine 2 di 3 Gamestop G3 Gamecube Left and Right Trigger Replacement: passo 5, immagine 3 di 3
    • At this point you should be able to remove the bumper along with its spring from the controller.
    • Clean thoroughly underneath the bumper and remove any dirt or debris before reattaching.
    • To reassemble the device, follow these steps in reverse order.
Conclusione
John Harrison
Membro da: 10/28/16
213 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 343
