Salta al contenuto principale
GameStop GS3 GameCube Controller joysticks replacement
Cosa ti serve
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: passo 1, immagine 1 di 2 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: passo 1, immagine 2 di 2
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: passo 2, immagine 1 di 1
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: passo 3, immagine 1 di 3 GameStop GS3 GameCube Controller joysticks replacement: passo 3, immagine 2 di 3 GameStop GS3 GameCube Controller joysticks replacement: passo 3, immagine 3 di 3
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: passo 4, immagine 1 di 3 GameStop GS3 GameCube Controller joysticks replacement: passo 4, immagine 2 di 3 GameStop GS3 GameCube Controller joysticks replacement: passo 4, immagine 3 di 3
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: passo 5, immagine 1 di 3 GameStop GS3 GameCube Controller joysticks replacement: passo 5, immagine 2 di 3 GameStop GS3 GameCube Controller joysticks replacement: passo 5, immagine 3 di 3
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
Conclusione
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,052
