Salta al contenuto principale
GameSir T4 Pro Battery Replacement
Cosa ti serve
  1. GameSir T4 Pro Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Battery Replacement: passo 2, immagine 1 di 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Battery Replacement: passo 3, immagine 1 di 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Battery Replacement: passo 4, immagine 1 di 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
Conclusione
3 Commenti
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Replica
Where can I buy this battery? Do You have a link to it?
Roberto Barros -
Roberto Barros - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 70
Tutti i Tempi: 1,565
