Salta al contenuto principale
GameSir T4 Pro Action Buttons Replacement
Cosa ti serve
  1. GameSir T4 Pro Action Buttons Replacement, Battery: passo 1, immagine 1 di 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Action Buttons Replacement: passo 2, immagine 1 di 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Action Buttons Replacement: passo 3, immagine 1 di 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Action Buttons Replacement: passo 4, immagine 1 di 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Action Buttons Replacement, Action Buttons: passo 5, immagine 1 di 2 GameSir T4 Pro Action Buttons Replacement, Action Buttons: passo 5, immagine 2 di 2
    • Remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Action Buttons Replacement: passo 6, immagine 1 di 1
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Action Buttons Replacement: passo 7, immagine 1 di 1
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Action Buttons Replacement: passo 8, immagine 1 di 2 GameSir T4 Pro Action Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the white rubber panel to get access to the buttons.
    • Put a small dab of isopropyl alcohol on a cotton swab, and clean around the area of your sticky button.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 108
Tutti i Tempi: 2,385
