Salta al contenuto principale
GameSir G7 SE Joystick Module Replacement
Cosa ti serve
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: passo 1, immagine 1 di 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Joystick Module Replacement: passo 2, immagine 1 di 2 GameSir G7 SE Joystick Module Replacement: passo 2, immagine 2 di 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Joystick Module Replacement: passo 3, immagine 1 di 2 GameSir G7 SE Joystick Module Replacement: passo 3, immagine 2 di 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: passo 4, immagine 1 di 1
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
  5. GameSir G7 SE Joystick Module Replacement: passo 5, immagine 1 di 1
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
  6. GameSir G7 SE Joystick Module Replacement: passo 6, immagine 1 di 1
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
Conclusione
Altre 4 persone hanno completato questa guida.
4Commenti sulla guida
Where to get the replacement parts?
Isaiah Hackworth - Replica
Where do you get the replacement parts from?
michaeljhs - Replica
Guida inutile senza ricambio
Matteo Andreani - Replica
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
Devoid - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 23
Ultimi 7 Giorni: 122
Ultimi 30 Giorni: 550
Tutti i Tempi: 8,119
