Salta al contenuto principale
Game Boy Pocket Back Cover Replacement
Cosa ti serve
  1. Game Boy Pocket Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Game Boy Pocket Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Game Boy Pocket Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Back Cover Replacement: passo 2, immagine 1 di 3 Game Boy Pocket Back Cover Replacement: passo 2, immagine 2 di 3 Game Boy Pocket Back Cover Replacement: passo 2, immagine 3 di 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 738
