Salta al contenuto principale
Game Boy Display Lines/Bars
Cosa ti serve
  1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: passo 1, immagine 1 di 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: passo 1, immagine 2 di 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: passo 1, immagine 3 di 3
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Game Boy Display Lines/Bars: passo 2, immagine 1 di 2 Game Boy Display Lines/Bars: passo 2, immagine 2 di 2
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. Game Boy Display Lines/Bars: passo 3, immagine 1 di 3 Game Boy Display Lines/Bars: passo 3, immagine 2 di 3 Game Boy Display Lines/Bars: passo 3, immagine 3 di 3
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  4. Game Boy Display Lines/Bars: passo 4, immagine 1 di 1
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
Conclusione
Altre 6 persone hanno completato questa guida.
Mitchell
Membro da: 04/03/16
184 Reputazione
1 Guida realizzata
Un commento
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,479
