Salta al contenuto principale
Game Boy Color Buttons Replacement
Cosa ti serve
  1. Game Boy Color Buttons Replacement, Battery: passo 1, immagine 1 di 2 Game Boy Color Buttons Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Buttons Replacement, Back Housing: passo 3, immagine 1 di 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Buttons Replacement: passo 4, immagine 1 di 2 Game Boy Color Buttons Replacement: passo 4, immagine 2 di 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Buttons Replacement, LCD Ribbon Cable: passo 5, immagine 1 di 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Buttons Replacement: passo 6, immagine 1 di 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Buttons Replacement, Motherboard: passo 7, immagine 1 di 2 Game Boy Color Buttons Replacement, Motherboard: passo 7, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Buttons Replacement: passo 8, immagine 1 di 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Buttons Replacement, Buttons: passo 9, immagine 1 di 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Buttons Replacement: passo 10, immagine 1 di 1
    • Remove the original buttons from the housing.
Conclusione
Altre 24 persone hanno completato questa guida.
Cal Poly, Team 19-47, Regan Winter 2013 Membro di Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membri
56 Guide realizzate
2 Commenti
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Replica
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 270
Tutti i Tempi: 27,788
