Introduzione
Utilizzare questa guida alla riparazione per sostituire lo schermo se è stato danneggiato.
Cosa ti serve
Panoramica Video
Rimuovi il coperchio della batteria posteriore premendo la linguetta e tirando verso l'esterno.
Usa uno spudger/una pinzetta/un'unghia per sbloccare la porta del cavo a nastro LCD tirando le linguette grigie sui lati verso l'alto (verso il bordo superiore del PCB).
Una volta che la porta del nastro LCD è stata sbloccata, il cavo a nastro LCD dovrebbe scivolare fuori molto facilmente e può essere rimosso senza forzare, usando le dita o le pinzette.
Guide does not indicate that the ribbon cable port should be UNLATCHED before attempting to remove the ribbon cable, I strongly suggest revising this as someone unfamiliar with these style of ports may assume that the ribbon cable is a compression fit and just needs to be "pulled" free of the port.
This is a terrible idea that will potentially result in tearing the ribbon! Please consider revising guide to add a step to indicate the proper method/detail for unlatching the LCD ribbon port! Thanks :)
Usa lo spudger per sollevare lo schermo dal pannello frontale. Posiziona lo spudger nello spazio direttamente a sinistra del D-pad.
This is a BAD place to pry on a functioning LCD. I used this exact method, slowly and carefully, and my LCD shattered.
Instead, remove the lens (it’s worth it to sacrifice the lens adhesive to save your LCD), and gently and slowly press with a gloved thumb on a corner to push it through from the front of the Game Boy. Let the adhesive release itself, don’t force it. If the room is super quiet, you should be able to hear a faint peeling sound, even if you can’t see anything moving. That means you’re doing it right; just wait and it will release.
Actually you can just pry under the ribbon cable. The LCD has a metal frame there that allowed me to slowly and carefully pry from that point without (re)breaking my LCD.
Yep. Same thing just happened to me :(
Altre 18 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Mitch ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
6 Commenti
Doesn't say where you can get new screen !!!!??
Doesn't say where to get screen from !!!??
Do this with the Game Boy Advance SP please!
It does not say where you can get a new screen
DONT DO THIS LIKE THAT!!!. The area of the screen in the space beside the D-pad is the only area where the LCD glass is completely exposed. It’s Literaly the WORST place to apply pressure, 99% chances for the LCD to break. There is a notch on the top right corner and another under the ribbon cable. Making your way from the top right to the left is far more safe.
To @flyingmcintosh, this happened exactly as you said it to me. Really wish I had seen your comment first but as soon as I applied the smallest bit of pressure where they outlined I heard the crunch; really frustrated with ifixit here.
