Introduzione
How to remove the back panel from a Game Boy Advance.
Parti
Nessuna parte richiesta.
  1. Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away.
    • Take the battery cover off by releasing the locking tab and hinging the cover away.
  2. Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove the six back panel screws using a Tri-wing Screwdriver.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove bottom back panel screw with a Phillips #1 screw driver.
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  5. Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
Conclusione
Altre 2 persone hanno completato questa guida.
Aldo Corona
Membro da: 25/01/2010
622 Reputazione
6 Guide realizzate
Cal Poly, Team 16-29, Maness Winter 2010 Membro di Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 39
Tutti i Tempi: 6,335
