Salta al contenuto principale
Galaxy Tab S 10.5 Camera Replacement
Cosa ti serve
  1. Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: passo 1, immagine 1 di 2 Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: passo 1, immagine 2 di 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Camera Replacement: passo 2, immagine 1 di 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Camera Replacement: passo 3, immagine 1 di 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Camera Replacement, Camera: passo 4, immagine 1 di 3 Galaxy Tab S 10.5 Camera Replacement, Camera: passo 4, immagine 2 di 3 Galaxy Tab S 10.5 Camera Replacement, Camera: passo 4, immagine 3 di 3
    • Use a spudger to disconnect the camera from the motherboard and then remove the camera.
Conclusione
Jordan Soto
Membro da: 08/26/15
3.276 Reputazione
6 Guide realizzate
USF Tampa, Team 3-2, Eyestone Fall 2015 Membro di USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,565
