Salta al contenuto principale
Introduzione
The Galaxy S20 has a hybrid SIM card tray. Ejecting this tray allows you to replace the nano SIM card, add a MicroSD memory card, or add a second nano SIM card (certain models only).
Ricambi
Nessuna parte specificata.
  1. Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band. If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
  2. Remove the SIM card tray. The SIM card will fall out of the tray easily.
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
Conclusione
Tarun Thiruma
Membro da: 20/11/2019
26.336 Reputazione
133 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 220
