Introduzione
Cosa ti serve
Remove all screws using your P#1 screwdriver. There are four large screws in the top and bottom, and the six smaller screws on the sides.
Honestly, the toughest part of the replacement are these three clips on each side. I found that prying the top two first makes it a little more easy.
After you get it unclipped, take out the screen assembly, and flip it over on its face.
Altre 9 persone hanno completato questa guida.
19Commenti sulla guida
if you use a blow dryer or heat gun on the front sticker - get it good and toasty, it comes out easier and in one piece. Also - blow dryer for the screen bezel - not too hot, but enough to loosen up the glue thats holding it down.
Last of all - on my gaems system - the connection to the lcd was both hot glue and solder - I had to use a de-soldering wick to take solder off the sides of the holding bracket.
Thanks for the tutorial - i had no idea how to get started
I'd like to see if I can put a 17" full 1080P HD or even the 19" one.. not sure if this case is the same size as their 19" model..but if it is.. their 19" model is a 720P display as well. I'd like to get an updated full HD display with better viewing angles.. any thoughts?
not a bad idea.. I just picked one of these up today for $20 that has a cracked screen. Wanting to use the case as a GCS for my R/c UAVs. It seems the monitor is no different than a standard 15.5" laptop LCD screen. I have a bunch laying around that I'm going to try and swap the cracked one out with. I have looked at the different cases and I will agree, I believe their cases are all the same dimensions with the exception of the mounting screws (19" screen would have mounting holes further apart than the 15.5") but with a little modification, im sure you could mount one in just fine. I also plan on creating a protective layer between the LCD and other hardware so something like this doesnt happen again when transporting it! I'll let you all know when its done
And if I accidentally break the connectors, is there somewhere I can buy a replacement for that? There was much more glue than I thought and the whole thing is broken now. (I'm having a rough day, if you hadn't guessed).
