Salta al contenuto principale
GPD WIN Silicon Pad Replacement
Cosa ti serve
  1. GPD WIN Silicon Pad Replacement, Remove the screw of the case: passo 1, immagine 1 di 2 GPD WIN Silicon Pad Replacement, Remove the screw of the case: passo 1, immagine 2 di 2
    • Remove the case screws
  2. GPD WIN Silicon Pad Replacement, Remove case: passo 2, immagine 1 di 3 GPD WIN Silicon Pad Replacement, Remove case: passo 2, immagine 2 di 3 GPD WIN Silicon Pad Replacement, Remove case: passo 2, immagine 3 di 3
    • There is a small space beside the keyboard, insert the pick and remove the claw
    • As you open the device, you can see that the flexible cable and the battery cable are connected. Then unplug the connector.
  3. GPD WIN Silicon Pad Replacement, Remove screws on the logic board: passo 3, immagine 1 di 2 GPD WIN Silicon Pad Replacement, Remove screws on the logic board: passo 3, immagine 2 di 2
    • Remove screws on the logic board.
    • Because some black threads are mixed, do not forget to remove
  4. GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: passo 4, immagine 1 di 2 GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: passo 4, immagine 2 di 2
    • Remove Wi-Fi antenna cable and LCD connector
  5. GPD WIN Silicon Pad Replacement, Remove the joystick: passo 5, immagine 1 di 2 GPD WIN Silicon Pad Replacement, Remove the joystick: passo 5, immagine 2 di 2
    • Remove the screws of the joystick and remove the flex cable from the connector.
    • Then, it is ready to pull logic board out of the case.
  6. GPD WIN Silicon Pad Replacement, Replace the silicone pad: passo 6, immagine 1 di 2 GPD WIN Silicon Pad Replacement, Replace the silicone pad: passo 6, immagine 2 di 2
    • You can access the silicone pad by removing the logic board.
    • Replace a sticky silicon pad
Conclusione
To reassemble your device, please follow these steps in reverse order.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
jp en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
noria901
Membro da: 06/15/18
509 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,237
