Salta al contenuto principale
GE TrueTemp Oven Light Bulb Replacement
Cosa ti serve
  1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: passo 1, immagine 1 di 1
    • Unplug the power cord from the wall outlet for safety purposes.
  2. GE TrueTemp Oven Light Bulb Replacement: passo 2, immagine 1 di 1
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. GE TrueTemp Oven Light Bulb Replacement: passo 3, immagine 1 di 1
    • Locate the metal strap holding the glass cover over the bulb.
  4. GE TrueTemp Oven Light Bulb Replacement: passo 4, immagine 1 di 1
    • Slide the strap to the side to free the glass casing.
  5. GE TrueTemp Oven Light Bulb Replacement: passo 5, immagine 1 di 1
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  6. GE TrueTemp Oven Light Bulb Replacement: passo 6, immagine 1 di 1
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  7. GE TrueTemp Oven Light Bulb Replacement: passo 7, immagine 1 di 2 GE TrueTemp Oven Light Bulb Replacement: passo 7, immagine 2 di 2
    • Screw in new light bulb in the clock wise direction.
  8. GE TrueTemp Oven Light Bulb Replacement: passo 8, immagine 1 di 1
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  9. GE TrueTemp Oven Light Bulb Replacement: passo 9, immagine 1 di 1
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  10. GE TrueTemp Oven Light Bulb Replacement: passo 10, immagine 1 di 1
    • Plug the oven power cord back into power source.
  11. GE TrueTemp Oven Light Bulb Replacement: passo 11, immagine 1 di 1
    • Press the button for oven light to come on.
  12. GE TrueTemp Oven Light Bulb Replacement: passo 12, immagine 1 di 1
    • View light to ensure the replacement was successful.
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 196
Tutti i Tempi: 17,488
