Salta al contenuto principale
GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement
Cosa ti serve
  1. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: passo 1, immagine 1 di 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: passo 1, immagine 2 di 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: passo 1, immagine 3 di 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: passo 2, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: passo 2, immagine 2 di 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: passo 3, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: passo 3, immagine 2 di 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, LCD Cover: passo 4, immagine 1 di 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: passo 5, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: passo 5, immagine 2 di 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 501
