Salta al contenuto principale
GBC Creative Laminator Gear Replacement
Cosa ti serve
  1. GBC Creative Laminator Gear Replacement, Gear: passo 1, immagine 1 di 2 GBC Creative Laminator Gear Replacement, Gear: passo 1, immagine 2 di 2
    • Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
  2. GBC Creative Laminator Gear Replacement: passo 2, immagine 1 di 1
    • Open the top of the device, and the inside of the Laminator will be exposed as shown.
  3. GBC Creative Laminator Gear Replacement: passo 3, immagine 1 di 3 GBC Creative Laminator Gear Replacement: passo 3, immagine 2 di 3 GBC Creative Laminator Gear Replacement: passo 3, immagine 3 di 3
    • Using the Phillips #2 screwdriver, remove the two 9 mm long screws on the side of the main component that fix the motor in place.
    • Pull the motor off of the main internal component to reveal the gear.
  4. GBC Creative Laminator Gear Replacement: passo 4, immagine 1 di 1
    • Pull the gear off of the motor.
Conclusione
Altre 4 persone hanno completato questa guida.
Yujia Tang
Membro da: 07/11/18
384 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Wilson Summer 2018 Membro di IUPUI, Team S1-G1, Wilson Summer 2018
IUPUI-WILSON-SU18S1G1
5 Membri
4 Guide realizzate
Un commento
Can you tell me where I might find a replacement gear for my GBC H200? I would like to find a brass gear but mine melted and need to find a replacement but no info for the gear. I think it is 17 teeth but not sure about the rest.
Jim Pruitt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 78
Tutti i Tempi: 3,524
