Salta al contenuto principale
GATEWAY ML6720 Wireless Card Replacement
Cosa ti serve
  1. GATEWAY ML6720 Wireless Card Replacement, Wireless Card: passo 1, immagine 1 di 1
    • Flip the laptop upside-down.
  2. GATEWAY ML6720 Wireless Card Replacement: passo 2, immagine 1 di 2 GATEWAY ML6720 Wireless Card Replacement: passo 2, immagine 2 di 2
    • Locate the wireless card cover, found on the middle-left section of the laptop as shown.
  3. GATEWAY ML6720 Wireless Card Replacement: passo 3, immagine 1 di 2 GATEWAY ML6720 Wireless Card Replacement: passo 3, immagine 2 di 2
    • Using the 1.5 mm Flathead Screwdriver, remove the cover screw at the top of the wireless card's cover plate.
  4. GATEWAY ML6720 Wireless Card Replacement: passo 4, immagine 1 di 1
    • Pull the wireless card's cover plate up and off to reveal the card as shown.
  5. GATEWAY ML6720 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Remove the two wires connected to the wireless card.
  6. GATEWAY ML6720 Wireless Card Replacement: passo 6, immagine 1 di 2 GATEWAY ML6720 Wireless Card Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 1.5 mm Screwdriver
    $5.49
    Compra
    • Using the 1.5 mm Flathead Screwdriver, remove the two screws at the top left and right corners of the wireless card.
    • Slide the wireless card up and out of the compartment.
Conclusione
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 234
