Salta al contenuto principale
GATEWAY ML6720 Hard Drive Replacement
Cosa ti serve
  1. GATEWAY ML6720 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop on to its backside.
  2. GATEWAY ML6720 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Locate the hard drive at the bottom left corner of the laptop's backside.
  3. GATEWAY ML6720 Hard Drive Replacement: passo 3, immagine 1 di 2 GATEWAY ML6720 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Insert the correct screwdriver mentioned in this guide.
    • Fully loosen and remove each of the two screws located at the top left and bottom left corners of the hard drive's cover plate.
  4. GATEWAY ML6720 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Slide the hard drive's cover plate out to the left and take it off.
  5. GATEWAY ML6720 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Pop the hard drive out of the compartment.
Conclusione
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 357
