Salta al contenuto principale
GATEWAY ML6720 Disc Drive Replacement
Cosa ti serve
  1. GATEWAY ML6720 Disc Drive Replacement, Disc Drive: passo 1, immagine 1 di 1
    • Remove the six screws with the Phillips #0 Screwdriver that secures the middle large piece of the back panel.
  2. GATEWAY ML6720 Disc Drive Replacement: passo 2, immagine 1 di 2 GATEWAY ML6720 Disc Drive Replacement: passo 2, immagine 2 di 2
    • Check to see if your laptop requires a screw(s) to be removed for the disc drive. Remove the screw (s) holding the disc drive down.
  3. GATEWAY ML6720 Disc Drive Replacement: passo 3, immagine 1 di 2 GATEWAY ML6720 Disc Drive Replacement: passo 3, immagine 2 di 2
    • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Conclusione
Semirah Dolan
Membro da: 10/31/16
113 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 210
