Salta al contenuto principale
GATEWAY ML6720 Battery Replacement
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Battery Replacement: passo 2, immagine 1 di 1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Battery Replacement: passo 3, immagine 1 di 1
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Battery Replacement: passo 4, immagine 1 di 1
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Battery Replacement: passo 5, immagine 1 di 1
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
Conclusione
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 415
