Parti
Nessuna parte richiesta.
There are 4 black screws that need to be removed on the top of the lid.  A 1.5mm flathead screwdriver will work on the star shaped screw heads.
  • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
  • Make note that two of the screws closest to the hinge are longer than the other two.
Aggiungi Commento
Remove the two side screws.
  • Remove the two side screws.
  • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
Aggiungi Commento
  • Use a plastic opening tool to remove the screen cover from the rest of the lid.
Aggiungi Commento
  • Your phone should look like the picture to the left.
  • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
Aggiungi Commento
  • Remove one screw located on the left side of the phone with the pictured orientation in mind.
  • This will release the logic board from the back case.
  • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
Aggiungi Commento
  • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
  • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
  • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
Aggiungi Commento
Conclusione
Raymond Caulder
Membro da: 11/03/2013
22 Reputazione
6 Guide realizzate
Clemson, Team 13-3, Benson Spring 2013 Membro di Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 551
