Salta al contenuto principale
Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement
Cosa ti serve
  1. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement, Ionizer Wires: passo 1, immagine 1 di 2 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement, Ionizer Wires: passo 1, immagine 2 di 2
    • Turn off the unit and unplug it.
    • Twist the lid counterclockwise and lift it up to reveal the black filter.
  2. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 2, immagine 1 di 2 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 2, immagine 2 di 2
    • Using a Phillips screwdriver, remove the two 2 mm screws holding the filter in place.
  3. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 3, immagine 1 di 2 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 3, immagine 2 di 2
    • Pull apart the clips holding the shell together.
    • The clips can be tight, so don't be afraid to pull hard.
  4. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 4, immagine 1 di 3 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 4, immagine 2 di 3 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 4, immagine 3 di 3
    • Using a Phillips screwdriver, remove the four 3.2 mm screws that secure the fan.
    • Lift the top clips off and pull the fan down and out.
  5. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 1.25 mm screws holding the motherboard in place.
  6. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: passo 6, immagine 1 di 1
    • Pull the cables away from the connectors in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 191
