Introduzione
Fairly easy task on this particular model. Only things you need are a small philips screwdriver (PH1 or PH2), a small flathead screwdriver (2mm) and a new CR2032 battery.
Parti
  1. Turn the laptop upside down and prepare the tools needed and the battery.
    • Turn the laptop upside down and prepare the tools needed and the battery.
  2. Remove the 4 philips screws that secure the back cover.
    • Remove the 4 philips screws that secure the back cover.
  3. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  4. With the cover removed, we can see the battery.
    • With the cover removed, we can see the battery.
  5. Turn the laptop around so you can see and access the battery. Release the battery with the flat screwdriver (1), then gently push it upward (2). Be careful not to let it slip into the laptop case or you will have to disassemble it completely.
    • Turn the laptop around so you can see and access the battery. Release the battery with the flat screwdriver (1), then gently push it upward (2). Be careful not to let it slip into the laptop case or you will have to disassemble it completely.
  6. If you have a multimeter, check the old battery. A good one should read 3 V or higher. A fresh one reads 3.2 V or more. In this case, the old was really bad, at only 2.7 V.
    • If you have a multimeter, check the old battery. A good one should read 3 V or higher. A fresh one reads 3.2 V or more.
    • In this case, the old was really bad, at only 2.7 V.
    • The replacement one is good, 3.22 V.
Conclusione
Altre 7 persone hanno completato questa guida.
nice... do you have information about the location of the cmos battery in the Fujitsu LH 532 model? rosez.v@hotmail.com
Victor Rosez - Replica
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 139
All Time: 9,781
