Salta al contenuto principale
Fujitsu Lifebook Stylistic Q584 Speakers Replacement
Cosa ti serve
  1. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 3, immagine 1 di 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Inner Back Shield: passo 4, immagine 1 di 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 6, immagine 1 di 1
  7. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 7, immagine 1 di 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Speakers: passo 8, immagine 1 di 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 9, immagine 1 di 2 Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 9, immagine 2 di 2
    • Use the narrow plastic opening tool to pry the speakers from the casing.
  10. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: passo 10, immagine 1 di 1
    • Unplug the speaker wires from the motherboard.
Conclusione
Un commento
Hello,
Thanks for this guide.
Is the ssd storage card replaceable on the q584.
I want to put a 256gb card internally.
Also, I notice a slot where the 4G /LTE modem goes.
Do you know the part number of that addition.
Thanks
Vince - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 549
